Hi folks
I've researched a fair old bit and followed some advice from other posts and have some findings - not 100% sure what the findings mean though so just looking for a steer before I get a professional on the job.
We have a Vaillant EcoTec 831 combi, 6.5yrs old. Serviced every year, September time.
Always been brilliant, no issues so far...
3 weeks ago woke up one morning and the heating hadn't come on. Trundled off to the garage where it's kept, and a warning was on (I think it was F22 off memory) relating to low pressure. Was at 0.4. I topped it up,probably only the 3rd or 4th time I've ever had to top it up and first issue of this nature.
It fired immediately, all was good, BUT, I've been keeping an eye on the pressure since. Cold (and I mean it's been off for 6hrs+), I noted the pressure 3 weeks ago at 1.3. When heating it goes to about 2.3/2.4.
But since then, over the last 3 weeks it's dropped to 1.2, 1.1 when cold and today down to 1.0. So suspecting a leak of some type I've read up on here.
First off, no known rad leaks. checked and double checked, including visible joints etc.
So I located the PRV outlet pipe and put a container underneath it. Topped up the pressure to 1.2 (cold), and turned the heating on. Went back about 10 mins later and the container was full (approx 200ml, give or take). Had overflowed a little too.
I emptied it, and went back again another 10 mins later and it's got a little more in there, currently boiler still firing to match the thermostat demand, pressure currently 2.3.
Have I located the source of the 'leak'? Would you expect an immediate discharge of water into the PRV pipe (please excuse my lack of correct terminology) straight away? And a decent amount at that?
If so is it likely to be a repressurise type job/diaphragm issue? To be clear those are WAY above my skillset and I'd defo be getting a professional in. Likely to be expensive?
Thanks all.
Thanks all.
