- Joined
- 11 Mar 2019
- Messages
- 41
- Reaction score
- 0
- Country
Every couple of weeks, my Vaillant (system) boiler fails to ignite and the error code F62 is displayed. I then press the reset button and the boiler ignites with the main burner working for maybe 30 seconds. The boiler then shuts down and displays error code F22. I then press the reset button again and the main burner ignites and the boiler works fine for several days.
The user manual states these codes mean the following:
Does the combination of error codes F62 then F22 narrow down the fault – or maybe they suggest what items I should start checking first to check the most likely cause(s)? Any tips would be appreciated.
- F62 = Gas Valve shut off delay – gas valve leaking, electronics defective.
- F22 = Dry fire – Too little water in the appliance, water pressure sensor defective, cable to pump or water sensor defective, pump blocked or defective, pump output too low.
