F and E system - Vaillant ecoTEC Plus 428 boiler.
Drayton Water and CH timer
Grundfos pump
2 x Honeywell 2-way diverter valves
Salamander pump (Not sure what that pumps tbh)
3 Storey house - 12 radiators ( 4 groundfloor, 6 first floor and 2 on the second floor, 1 bath, 1 shower). Tads have TRV’s and have been bled.
Not sure how many issues I have but here goes:
Main issue - if you turn the CH on using the Drayton timer the boiler won’t fire. If you turn the HW on via the timer, wait for about 30 seconds the boiler fires then you can turn the central heating on and away it goes except the groundfloor radiators don’t heat up (2nd issue). Sometimes the pipes leading to them get luke warm but not usefully so.
If I leave the hot water on and CH for a while and then turn off the HW the GF radiators begin to get warm.
I put the pump to 3 and that appeared to cause the radiators to heat up a bit more downstairs but again not usefully so.
I’ve looked at the 2 way diverters. When everything is off the lever stays to the left (away from the manual setting) when things are on the lever doesn’t seem to move from this position. Again when the system is off there is resistance when I gently push the lever toward the manual setting, letting it go it springs back its starting position. When the system is on the lever on both valves can be pushed to its opposite end with no resistance.
Not sure I want to leave the valves in manual.
The system has worked in the past.
Many thanks in advance.
Grundfos pump
