VAILLANT ECOTEC PLUS 624 - FLASHING "CON" MESSAGE
30 Dec 2007
Help please!! What does this mean? How can I get my boiler re-started. Thanks.
PS Status code is S.0 which means no heat demand...
Thanks!! :(
Presumably you disconnected the mains power for a few minutes and then repowered ?
It very occasionally works on some microprocessor devices.
Does anyone know what the actual PCB fault is that causes this?
It is a communication fault between the main pcb and the user interface.
It is usually caused by a low voltage short circuit, causing an incorrect potential difference in VDC to the UI
But I gather its a main PCB fault. Do you know exactly what is the cause on the main board?
