VAILLANT ECOTEC PLUS 831 2 AMP FUSE PROBLEM
16 Apr 2012
Cleveland
Vaillant Ecotec Plus 831 keeps blowing the 2 amp fuse on the circuit board for no apparent reason , I replace it and it runs for anywhere between 10 minutes and 10 hours before blowing again. Pump ,fan , hot water and heating all working till it blows. HELP :?: :?:
You seem to have an intermittent fault. They can be difficult to find.
Often its the pump. If thats mains powered then it can be supplied from a seperate supply with a 3A fuse.
The fuse on your boiler is fine, its no problem, its doing its job and blowing when the rated current is exceeded. Good things fuses!
Tony
The pump has been checked and seems fine . The fuse sometimes blows even when there is no water or heating on. :?
Exactly how has the pump been checked?
Its a while since I looked at the mains imput circuitry on that model.
It might have an RF filter or surge spike limiter and those can sometimes cause intermittent fuse blowing.
I would not discount the pump yet! They are often spun for a few seconds every 24 hrs.
Tony
