Hi all,
Decided to register here for some help before calling the dreaded Vaillant Service line. Have had my Ecotec Plus 837 for about 2.5 years, however it hasn't been used for 6 months due to refurbishment.
I left my handyman with the job of refilling the system yesterday and got a phone call to say water was pouring out of the wall. When I got home he had the front panel off and had been trying to run the systems with one of the loop filling taps in the open position. As such water had been pouring out of the pressure release 15mm pipe to the outside. I closed these, drained the system and refilled to a suitable low level on the mechaical pressure guage on the front of the unit.
At first when starting it wasn't igniting at all and after a while was coming up with F75. Googleing this showed it was down to the water pressure not being read as going up in a timely manner. This was confirmed by reading the digital sensor which did not show change during startup.
I tested manually adding pressure to the system when starting up (using the loop briefly) and the system ignited fine, but would not keep running for very long on my two tests before F75 came up again.
Next morning I showed this to my handyman. He proceeded to pull down the electronics flap and pulled a red switch to see if that helped. It turns out that as well as leaving the taps on he had been guessing at what to press to fix it. The red button has Bar written on it and sounds like it is adding water to the pressure vessel. Lord only knows how much this has happened.
When I turned on after this it came up with an F20 error code straight away. The only other check I have looked at is to try moving the pump thread with a screw driver. This would not move easily so I did not force.
Advice on what to do next would be appreciated.
