Hi all this is my first post on the forum, although I've managed to get quite a few answers from you all already by searching through different threads (thanks all) but i'm a bit stuck at the mo.
I'm having a problem with a vaillant ecotech 831,there was no hot water but the ch was fine Ive changed the diverter valve and got it working for about 2 weeks but the customer just phoned to tell me it's stopped again. When the boiler was going through the start up sequence there was a noise that sounded like a gear slipping that was coming from the diverter valve area which i thought might have been the actuator not working but after replacing the diverter itstill made the noise on start up, but i left there with the boiler working.
I'm not really that experienced on vaillant boilers and I'm hoping to go on the course this year but any advice would be appreciated. When I replaced the diverter valve I took off the plate heat exchanger and cleaned it through I also drained down the system and flushed out best I could with the filler loop (haven't got a power flusher) until it ran clear I didn't put any inhibiter in as I wanted to make sure it was fully working before I added any (glad I didn't I don't think I can afford to spend any more on this job) I'm going back on Monday as cust is away any advice would be gratefully recieved.
