Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Obvious question. Did you set the mode switch to timed mode i.e. pointing to the clock symbol and did you ensure that the tappets were out for off and in for on?
The indicator light should go out when the timer is in an off mode.
