After being completely let down by a young newly qualified RGI who was a good friend I have been left to search the forums for assistance. Please help. I have a Vaillant Turbomax VUW 242/1E that is not behaving as it should. It had two faults, one being a leak. This was sorted out by my friend the RGI who changed something in the diverter valve and this stopped the leak. He also changed the microswitch on the valve as this was a little damaged. He took care of the leak quite quickly but he has been having a lot of problems sorting out the second problem which is that intermittently the boiler ignition indicator light starts flashing when the hot water taps are turned on and hence burner not lighting. The water tap light comes on and after about 30 seconds or so the flashing ignition indicator (like egg timer symbol). The fan light does not come on and so the burner doesn't light. If I reset and then turn on the hot water, the boiler sometimes fires up and sometimes doesn't. The central heating usually fires up if turned on, but turning the hot water on causes the boiler to go off (ignition indicator flashing) more often when the heating is on. The plumber has changed the air pressure switch as well as the flow switch and the thermistor. He flushed the system and cleared any blockages in the pipes to flow switch etc. and set the the system pressure to 1.5 bar. He didn't seem to think it was the diverter valve causing the problem as the microswitch on the valve works perfectly (i.e. the lever goes up and down as it should on water demand) and is new. I have had enough of constantly calling this young man for his services so I am turning to you guys with a lot more industry experience for help to shed some light on what the actual fault is before I get someone in to start replacing parts again. I have recently noticed that when the boiler doesn't fire the flow switch lever doesn't seem to rise, the lever of the diverter microswitch seems to be working fine though. Wedging something under the flow switch lever to lift it gets the boiler to ignite when the hot tap is turned on but the flashing ignition indicator returns as soon as the water tap is closed (even with something still holding the lever up). I have also just noticed that the 22mm central heating flow pipe seems to get hot when heating is off and hot water is turned on. Please someone, let me know what may be the cause.
