Combi Boiler: The problem Iam going thru with Vaillant TurboMax Plus 824E My issues started 4 weeks back, problems with the boiler cutting out after a few minutes. Hot water perfectly fine . The problem we are having is with the central heating side. The boiler starts up and makes the usual noises. The flames light and remain lit for around 2 minutes, after going off. The boiler continues to make the noise those (as though it is fully working). After about another 5 minutes the flames light again for another 2 minutes (It doesn't reach the temperature-It gradually goes upto 30c and cut off the heating. When the temp gradually reached 18c it starts again for few minutes and cut off. This cycle continue until I turn off the CH. Well after running for couple of hours radiator gets warm at the bottom only. ( All rads bleed) I thought could be room thermostat. I have changed two thermostats from different brand but NO luck. FYI-Its nearly 20 years old combi boiler.
Boiler shows NO Fault Code.
