Hi, i'm new to this forum, so please excuse me if I don't give all or correct info needed straight away.
I tried to fire boiler lately, after loading system to over 1mb and bleeding rads, only boiler fires up, goes into ch mode, reaches temperature of 82 degrees very quickly and shuts down then when temperature drops it fires up again up to 82 degrees again and repeats this cycle!
There is no fault code showing, status shows it going through S2, S3, S4 then when it shuts down it shows S7 and then cycles again?
Please can anyone tell me if they've had the same problem?
I've changed the diverter valve, checked operation and this works fine!
DHW works fine, would that show pump working too?
Please help....
Thanks.
Please help....
Thanks.
