Hi all,been a horrible few cold days,here`s what ive done so far
Vaillant VCW 242 EH
started off with a cold spot in a rad, so i flushed the system,filed into the system some F3 cleaner, and flushed that out 2 days later.
cool.
boiler has worked fine for the last year,even last winter.
always had a pressure problem,turned out my expansion vessel needed pumping up,so thats sported,all going well i thought.
until yesterday,central heating kicked in,cool,then thought it was cold in the house still,boiler was wuring away but no ignition/flames.
so i did the following
right,bear with me,it does get better !
i spend the day cleaning out the wrong parts ha ha.
i took apart and cleaned the servo control valve,was gummy but now isnt.
Then i took off and took apart the water section,cleaned the diaphragm and all is well there.
the reason i did this was because i mistook the DHW microswitch as the C.H Micro switch,hence my cleanin of these bits,i then started to realise my mistake !!
time was gettin on and i was still where i was this mornin,no ignition.
Then i realised i should of been lookin at the diverter valve and the microswitch on that for the C.H,DUH !!!!
so i worked it out,lubed up the shaft that the actuator is on and adjusted the screw so the microswitch now activates better and i now get IGNITION, YAY !!!!!
But,not for long, after,and it can be a variable amount of time, 10 seconds, 1 minute, 30 seconds, 5 minutes etc flames go out and the error lite comes on and the black button pops out and it shuts off,huf huf huf !!!
so now i get ignition,but not for long, any ideas on that ?
the manual says gas related which i wont touch.
but could it be a dirty diverter valve still as i havent took that apart yet ???
i see a nice clean 2nd hand one on the bay for £15
was well chuffed when it fired up on its own,then it went out sob sob
gutted,done so much,got it igniting but it wont continue
Vaillant VCW 242 EH
cool.
