Hopefully one of you expert guys can help me with this one. The boiler will not fire up when a tap is opened, with the RH switch in the instant position.
The water section diaphragm has been replaced (was knackered), pin works fine; the pair of microswitches which the pin operates has also been replaced. The switch pcb has been replaced as it had a small burnt section. CH works fine, and 'warm start' DHW works well, so we are relying on that at present.
What else could be the cause? I've read that the diverter valve wax stat could be the culprit. Are the other microswitches a possibility?
Any help gratefully (and graciously) received.
Rog
Rog
