What is the time delay between burner (on/off) when the CH is ON, at the moment my boiler is set to dial 5 and the timing is 5mins burner ON and 9mins OFF (delay), is this normal?
For some reason the timing/delay screw has been adjusted recently by the engineer, and i feel that time/delay between cycle is excessive.I have contacted him and he suggested adjusting the screw till desired settings.
What should normal time/delay cycle be?
How to i reset to factory default setting?
Thanks in advance for advice/comments.
