First time posting on here but here it goes.
I have an ageing Vaillant VCW242 boiler that up until now has been working fine.
I have not had any work done on this boiler in the last 3 years since the heat exchanger was replaced apart from regular services.
The problem I am having is that the DHW side of the boiler is working just fine but when the CH is switching on there is nothing happening.
The pump, fan, burner do not start hence the diverter valve does not move to position for CH on. The flame lock out light remains off, water pressure is above 1bar and doesn't lose pressure.
I have tried with the pump in the constantly on position, using the bridge in the control box, which starts the pump and does move the DV into the correct position but nothing again not even the fan.
I have removed and tested the micro switches attached to the DV they check out ok, I have tested the CH over temp switch which checks out ok, I assume that the air pressure switch and fan are working ok as the DHW works fine, I have also checked the plunger on the Servo valve which is ok and clear of the cam, I have also bridged the thermostat/timer terminals to count out the timer.
Could anyone tell me if there is more I could try or if anyone knows what the fault could be.
Thanks in advance for any input you may have.
Tony
Tony
