I’m in the process of replacing my Glow-Worm Space Saver 50 (Y Plan) with the following:
Vaillant 415 ecotec (heat only) boiler,
VRC430 Weather compensator
VR65 control panel.
I currently have a Hot Water Cylinder with a Potterton variable cylinder stat. What I’m trying to workout is what the impact will be for the domestic hot water features on the VRC430 if I connect the cylinder stat to the VR65? My thinking is that the Cylinder stat will continue to control the target hot water temperature - is this correct?
Will I need replace the cylinder stat with something more appropriate?
Thanks,
Chris
VR65 control panel.
Thanks,
Chris
