Looking at Vaillant VRT 360
The dimensions are quite large but it is the depth that concerns me - 34 mm.
Does anyone know if this unit can be recessed into a wall or whether it has to be surface mounted? The installation instructions on the website don't state but hint at surface mounting.
Has anyone got one fitted in a lounge? I'm concerned that it will be a bit of an eyesore.
Main reason for fitting one is actually to gain separate temperature control of DHW. As I see it, without the VRT 360 or similar, you can only set a single temperature on Vaillant ecotec boiler. If you want maximum efficiency you need lower flow / return temps but this conflicts with DHW requirement at 60 deg? I have to set my temp on the boiler close to maximum if I want to stop the boiler from short cycling when heating DHW - makes sense to me because if I want DHW @ 60 then boiler has to heat flow to hotter than this, say 70 deg?
Perhaps I am missing something?
