Hi all, just replaced a seized diverter cartridge in a pals 2y old Ecotec plus 831 R2 combi, that's all ok now, however his wife mentioned that the tap water temp. was very hot, it was set at 55 which should have been ok, but I reset it to 50 and saved it. When the hot tap is opened the water temp and the display goes up to around 68-70 in around 30 seconds and you can't hold your hand in the flow. Comfort 'C' is on, there are no codes and the sensor is in good contact with the heat exchanger. Any ideas??
