I've seen Vaillant weather compensation discussed recently but want further opinions.
As a precursor to a loft conversion in an unextended 2 bed Victorian terrace, I intend to replace my S plan vented system (Potterton Profile 50e feeding 7 rads via microbore and 22mm gas supply throughout run; no TRVs) with a unvented cylinder and system boiler.
It will remain a one-bath property but I don't fancy a combi.
The mains is supplied by a 1in lead pipe which delivers a measured 27l/m off peak and c. 22 peak to kitchen and bath cold taps. I've not had the pressure measured.
I'm almost sold on having a Vaillant 618 and 155l Unistor connected via the VR65 control centre, but am dithering over replacing my Honeywell CM927 room stat (in hall) with a Vaillant VRC430 weather compensation unit. We do have an appropriate N facing external wall for the sensor.
Questions:
1) Should I insist on a pressure test (X bars..) from installer even though the flow rates seem adequate?
2) Would a very disruptive upgrading of the 1in lead supply pipe to 25mm plastic offer any improvement in flow rate (I doubt it..)?
3) What are the pros/cons of having the VRC430 weather comp. plugged into the boiler fascia - where it doesn't monitor room temp - or having it wall mounted in the hall, where it would monitor room temp?
The new boiler would be in the kitchen, which faces SW and gets lots of sun.
Thoughts from Vaillant installers (gas4you, simond..) very gratefully received.
cheers
Questions:
cheers
