    Dismiss Notice
vaillent ecotec combi storage 973
Discussion in 'Plumbing and Central Heating' started by mowerman400, 13 Feb 2011.
  1. mowerman400
    mowerman400
    13 Feb 2011
    14
    Thanks Received:
    Northamptonshire
    Country:
    has anyone had any problems with this boiler would you recomend it
    the problrm with most combi boilers there is a lot of dead water before it runs hot would fitting one of these splve the problem they are expensive i no
  2. Sponsored Links
  3. mowerman400
    mowerman400
    13 Feb 2011
    14
    Thanks Received:
    Northamptonshire
    Country:
    the cheapest one i found on ebay at £1199 does anyone no were i can find one cheaper or good second hand one
  4. Morris40
    Morris40
    9 Jan 2011
    231
    Thanks Received:
    29
    Middlesex
    Country:
    the valliant range of combi's have a comfort setting so when turned on if you open the hot tap you will waste a lot less water as it is designed to deliver hot water quicker, 973 is expensive and very large due to the storage tanks very good boiler though as are all Valliant, like any boiler though it needs servicing yearly or you will have problems
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
