Vailliant Ecomax 828E
22 Mar 2006
Yorkshire
Hi All
My vailliant combi boiler has developed a pressure fault. I have noticed the pressure guage when boiler is cold is over 3.5 bar. It should be 1.5 bar and should go up slightly when heats up and should get back to 1.5 bar.
The boiler is working ok but this problem is worrying me. What is causing the pressure build up. I have searched this forum for the possible cause. Some say filling loop may be passing, some say expansion vessel could be faulty. I have checked the filling loop the valve shuts firmly. I would appreciate positive feedback. Thanks in advance.
Basecoat
Hi All
Basecoat
Hi All
Thanks for your response Buck51. Last night I had to bleed 5 upstairs radiaters. 2 weren't heating at all and 3 three were part heating. This indicates air getting into system. Where from though. Come on you experts. You helped me before please help me again. I and my young family can get by with part elec heating but I have 84 old mother needs to be kept warm.
She came home last wednesday after 6 days in hospital after a mini stroke. can Agile and his collegues please kindly assist. Thanks in advance.
Both things are correct check the filling loop and make sure it is not passing
Then if the pressure goes up nest thing to check is the expansion vessel and in the very occasion the DHW Plate heat exchanger may be passing but this rare
For the sake of your 84 year old mother chop chop do the basics then come back
