valliant combi
6 Apr 2007
Yorkshire
I have a problem with the pressure it goes up to 3bar when running then goes down nearly to empty when off. I've blead all the radiators and all are full with no air pockets .I have noticed a small leak from the pressure release valve could that be the problem, and is it a DIY repair or do I need a plumer.
You need to check the expansion vessel. Check the stickys and look at FAQ.
