Depending on make and cause, you may be able to change just the motor, or just the head/actuator, or you may have to change the entire valve after draining down.
got a friend of a friend, he changed the pump but then discovered it was the switch! got one on order now
the trick with the pen worked house is toasty now!
thanks a million
