I had my heating system power flushed a few weeks ago, conventional boiler system. Two questions if anybody can help. When the hot water heating starts up, normally twice a day, there is alot of water 'rushing' and gurgling sounds from the pipework in the airing cupboard which it didn't use to do before power flush. A new pump was fitted also as old one really gunged up, speed set on 3. The red valve handles at the bottom of the photo are not full open. Should they be? Other question is regarding the air bleed vent at the top of the pipe in the other picture, I am getting air that needs bleeding from two of the upstairs rads every couple of days, not much but enough to make is sound if a ball bearing is rattling about. The bleed valve at the top of the pipe won't bleed air or water. The hole must be blocked, I have cleaned it out once before but only on a drained down system. If I try it with a filled system and clear the hole am I going to get a fountain like jet of water that would prevent me getting the screw cap back on?
