valves on boiler
16 Jul 2009
Hull
Is shutting the isolation valves on the flow and return to the boiler to drain the boiler a bad idea. I.e they usually leak afterwards?
Do it only if you really have to... or close them if you fancy a bit of extra work draining down and replacing....
It all depends on the boiler model.
Many are fine and many also leak too!
Tony
And guess there is no way of knowing if this model of boiler will be ok untill I turn them off
