vanity basins
17 Sep 2009
Bradford
hey, I am thinking of getting a vanity basin from b&q when buying my bathroom suite. However I have never installed one before. Are they quite easy to install? Do you usually have to cut out for the the basin? Or is this already done? Thanks for any advice.
the basin fits on to the vanity unit and rests on the outer vanity unit panels
OK thanks does the unit come pre-cut for the basin? Also how does the vanity basin usually fix to the wall, L brackets? Thanks for any help
you don't need to cut nothing.
only sometimes the rear or bottom depending where the waste and pipeworks coming through.
use a fixing kit.
is the unit like this one ?
Yes the ones I've been looking at at b&q look like that. Thanks for your help is the some holes in the basin for the fixing bracket just like a normal basin
. Thanks
OK thanks so does the basin come separate to the unit and attached on to it by l brackets or something thanks.
