Varem water pressure tank thinks the problem
17 Jun 2008
Lincolnshire
I have a borehole for our water supplies. This is fed into a pressurised 60ltr water cylinder. The problem we have is that the water is spluttering and shooting in spurts out of the taps. I have looked at the cylider and the pressure gauge says 4.75bars when it should be 4bar. Is the uncrease (I don't understand why it has gone up) the problem? And how then if it is the problem do I resolve it? Otherwise any other ideas would be appreciated.
Many thanks
Tony
HI
there is water in the pipes/system.water could be entering from the mains specially if it supplied from bore hole.to overcome this you can fit air vents.
Yes there is water in the pipes and tank. In fact I ran the water and went back to the tank to see waht was happening. The pressure went above 5bars. A little worrying. The water splutters out and is white, which is full of bubbles, that clears obviously in a little while in a glass.
Tony
HI
sorry i mean AIR in the pipes not water.if air is being drawn then it causes problems.and the water pressure should not be that high .you can fit pressure reducers to limit to about 3bar.
Found the problem, the diaphragm was clogged up with silt and therefore couldn't cut the cut out off for the pump. In that case me thinks the pump was still pumping and any air in the cylinder was being pushed out into the taps with too much pressure. Resolved anyway. Just got a leek to contend with, but thats the least of my problems as we have water now. Best water there is straight from the ground and no water rates.
Tony
