I am currently up to roof level on my single storey small extension (1.7x3.3m) with a few issues and was after some guidance before BC come and intergate me!!
I originally allowed for a vaulted ceiling with a 50mm vented air space. make up 100mm K7 with 50+12.5 K18 board /Breathable felt/battens and slate. (this is fixed to the existing 9 inch solid wall).
Now heres the issue, i have a catnic lintel above the door/window but with height restrictions and trying to gain as much pitch as possible (22') i'm left with one brick between lintel and bottom of joist. With barely any soffit and the facia having guttering in front how can you get an airflow into the roof space?
Now i've come across this problem it seems a bit much for myself to get right and as a DIY job was wondering if i should go down the full fill unvented option with the use of sarking board or (if i read it correctly) a breathable sarking membrane?
Was wondering on peoples thoughts and do i have to consider any other aspects?
