Vauxhall zafria 1.8 auto p1895 fault
14 Jul 2007
Cambridgeshire
Car was running fine, put in new headlight bulb so had to remove airbox and bend it up a bit , now car is missing on tick over and sounds like its running on 3 cylinders fault code comes up above.
any help paul
When you lifted the air box out of the way, did you disconnect any air pipes in the region, or pull the MAF connection wiring unduly hard?
John :)
