I would be grateful for advice from the learned people on here about whether I (the lessee) or the freeholder should be paying to replace a window in my flat. Please could you read the latest email below sent to the management agency which I think explains the situation, and let me know your thoughts.
I have been reading the lease for the property and my understanding from this is that wear and tear damage to the frame around the window is the responsibility of the freeholder, whereas if it is just the window that needs replacing this is done by the leaseholder.
In this case it is both the wooden frame around the window attached to the building that has rotted badly, as well as the frame around the Velux window itself.
As the frame attached to the building is damaged, does this affect where responsibility lies for its repair?
I seem to recall that as part of the major maintenance work that was carried out on the front elevation of the whole building last year and paid for out of the maintenance budget, repair work was done on the exterior window frames for the 1st and 2nd floor flats. Does this set a precedent for similar repair work to be done on the window frame in Flat 6?
I would just like to be absolutely certain regarding responsibility for this work before any cheques are signed as quotes that I have been obtaining indicate that it is likely to cost several hundred pounds.
