vented to sealed change over
28 Apr 2008
how do you convert a vented system to a sealed system and what do you need?
whre does the exp tank go , any where or not . thanks
when you say "what do i need" then the sensible answer would be a heating engineer!!
If you want to do it yourself then you need a basic knowledge of the system you are working on, a wet and dry vac and faith.
Sorry, if you want a sensible answer then alot more info is needed as its not as simple job as made out.
