Having an extension built, getting underfloor heating through extension and adjoining existing room, and our boiler has definitely seen better days.
...so getting the boiler replaced at the same time seems like a no-brainer. So far, so straightforward. But a friend recently recommended I get a 'Megaflo' (other brands do exist) at the same time, to future proof my growing children wanting multiple showers a day, and to improve our shower water pressure. It sounds on the surface like a good idea.
What I have rapidly discovered is that this area is a minefield for the uninitiated, and the builder's recommended plumber, whilst apparently very good (all the other tradesmen have been so far), is flaky when it comes to answering questions...taken 2+ weeks to get a quote out of him, and that's a one-liner.
...so can I ask you good people for advice, please?
Current system is very old-school heat-only boiler in an upstairs cupboard with vented tank underneath and a water tank in the loft. With 10mm microbore for the c/heating. House is a 1990 build 4-bed / 2.5 bathroom with 13 radiators + 2 large rooms for underfloor heating.
Questions:-
1) Boiler - Do I HAVE to get a system boiler if I'm going for an unvented tank? Or does an old school heat-only with a pressurise kit work as well? (Don't want a Combi, before that's mentioned)
2) Boiler output - my maths suggests 25kW would be a sensible figure - have I got that right?
3) Unvented tank - plumber has suggested a 200 litre tank. 2 adults / 2 kids, only very occasional visitors - does this sound OK or a little parsimonious?
4) Unvented tank - risk to old pipework? I can't find a lot out about this - is it a serious consideration, or are they typically OK? (Not asking for guarantees, just an assessment of the risk that we're going to spend £4k here and then have to spend the same again or worse chasing leaks all round the old pipework)
5) Unvented tank - are there any brands to avoid, and is there a recommended or a minimum spec? I figure I only need a single coil indirect system, but do they automatically come with a backup immersion heater as a rule, or is that not a thing?
6) No-one has measured current mains flow-rate and pressure...searching and reading on here I assume that's a critical first step...but what minimum values should I be looking for?
7) Maintenance - is an unvented system any/much more onerous for an amateur like me to look after (radiator bleeding and generally keeping an eye on) than our current old-school system?
I know the recommended advice is to get competitive quotes / consider getting our own plumber in, however our trusted plumber retired pre-Covid, and we've since gone through 2 others who've come out, serviced the system once, then gone quiet (presumably because finding good ones round here is impossible). And the only other recommendation we've been given has ignored 2 voicemails and 1 text...clearly doesn't need the business. So we'd just be going to google and hoping some random stranger was better than the builder's random stranger.
(Quote is £4,500ish for a Vaillant heat-only boiler with pressurise kit, a "200 unvented cylinder" (so presumably Gledhill or Vaillant), fit 4x new radiators to replace corroding / old ones, plus drain down, fill and test)
Thanks very much,
Martin.
Questions:-
Thanks very much,
Martin.
