Our house is about 20 years old and this is the top of the toilet vent stack where it goes through the roof. I had the misfortune to knock this pipe this evening and 20 years of condensation released itself from the low point of the curve. I'm not sure what the builders were thinking as this is only held in place with a push fit and so it seems inevitable that it would eventually fill up with condensation and the fitting wouldn't be able to take all that weight.
I have cut out the damp insualation and put a dehumidifier in place to dry the remaining damp. What is my best option for a permanent fix for this vent?
1) Cut back the grey pipe and use the flexible section to connect to the roof vent without the u-bend?
2) Cut back the grey pipe and install an air admittance valve (Durgo) on the end of it?
3) Another option I haven't thought of?
Thanks in advance for any advice you can give me.
