Venting cloakroom and small ensuite
12 Feb 2015
Surrey
I have a cloak room and an ensuite next to each other, in the middle of the house, with no possibility of venting.
There is a small crawl space above the ensuite ceiling to house one or two inline extractor fans and ducting hoses.
I want to merge the two hoses and route them through the adjoining bedroom out through the external wall.
The hoses are standard 100mm, but that would create an unsightly "box" at the top of the wall in that bedroom.
Could I use a smaller radius hose, say 50mm instead? The length would be about 4.5m.
Maybe it would be more noisy with a smaller pipe? Or not possible?
1. I assume the smaller pipe would be 50 mm in diameter rather than radius.
2. A pipe of 100 mm diameter has a cross sectional area 4 times that of one of 50 mm diameter.
3. So to create an equivalent capacity you would require 4 x 50 mm hoses.
4. Could you consider taking the 100 mm vertically through the bedroom and into the loft, and create an external vent in the loft?
for air to egress from the space, it must have an ability to draw in air to replace it or it stands still. Ensure you address that issue or whatever you do will be meaningless
Sorry I meant 50mm overall diameter instead of 100mm.
I am not sure what capacity I need, I do not think there is a minimum mentioned anywhere? So if there was a partial blockage in the hose you'd not know it for ever. Was my thinking.
I did consider vertically up, and down, may still do that if needs be... Up is hard because there are rooms in the loft and will have to climb up on roof, cut tiles, risk leaks. Vertically up hoses are very bad as condensation then runs back into places that cause damage. Had this happening at an older house! Straight down there is an underground basement, but very hard and complicated too.
Well, you do not spend too much time and then you open the door.
