Hi all,
I'm looking for a bit of advice on the verge options for a slate roof. My roof has been re-roofed in SIGA slate and having become suspicious recently I have read around the subject of verge construction and there appears to be two main methods - wet bedding or dry verge capping strip. The use of clips for verge tiles seems to be an optional thing unless it's a new build.
My verge has none of the above, the slates are sat overhanging the gable end (approx 50mm of slate overhangs) and then the PVC fascia boards have been fitted and a bead of black silicone applied along the join. When I questioned the builder he said his roofer said "it is completely correct to slate over a barge board and that older properties are done like this and roofing hasn't changed much over the years".
When surveying verges locally I seem to find most slate arrangements have a pointed verge.
Comments and advice much appreciated.
