Veritas 8 - want to stop bell box flashing
27 Oct 2014
West Midlands
Hi
I moved into a house with a Veritas 8 alarm recently and this weekend I changed the security code.
Only since then, the red and green lights on the bell box outside are constantly flashing - even when the alarm isn't on.
Note: To change the code, I followed the instructions I was left, and that didn't work. So I googled and found other versions of the manual which gave a combination of buttons that did work and enabled me to change the code. I'm thinking that there must have been unintended consequences when I pressed the buttons that the first set of instructions said to.
Can anyone tell me how to stop the red and green light on the bell box from flashing?
Your bellbox is working correctly. LEDs must be always flashing. This default function has no relation to change of the code or what you can control from the panel.
The way to stop it flashings is to open bellbox and disconnect/cut LEDs wires.
As above, it's working correctly and acts as a deterrent to would be thieves, showing them it's not just a dummy box screwed to the wall.
Also depending on the box, the speed and sequence of the flashes can indicate a healthy system or an issue.
My advice would be leave it alone.
