Moving into a new property shortly which has a veritas 8 panel (fitted 2005). I will be removing this panel in order to fit my own alarm so i can have control over the system, engineer codes etc.
I noticed that the power LED on the main panel was flashing green when i last looked around, from experience this doesn't mean its working correctly as i would think this would be a solid green. Anyone comment on what the flashing green means?
Also, when i come to remove the panel and bell box im guessing as soon as i remove the lids that the tamper will set the alarm off. Not ideal to fall out with the new neighbours straight away!! so has anyone any idea how i can prevent it going off without having any of the codes? Last occupiers never used it and dont know the codes.
Regards
Regards
