It is necessary to bring a 10mm twin and earth from basement to loft above a three floor town house. There is a fire proof vertical shaft with soil stack pipe and other services. Getting into this shaft other than top and bottom to clip the cable to the wall would be difficult and result in need to re-decorate.
Can a vertical catenary be used to support the cable on a galvanised steel cable at regular interval and this pulled up into the shaft ?
<<edit>> This is to supply an air con with high start up currents.
