I'm in the process of having an old combi boiler replaced with a new one in the same location. An installer has surveyed the site and mentioned that the vertical flue which currently exits through a flat roof fails gas safety rules since its terminal is not 30cm away from the house exterior wall.
The installer has suggested moving the flue terminal outwards to a more suitable position. Whilst this sounds sensible it does involve cutting a new hole in the flat roof and sealing the old hole which is obviously expensive.
Not knowing anything about gas safety law I would like to know if it is admissable to modify the existing flue arrangement by adding a 90 degree bend so that the terminal points away from the exterior wall and meets the 30cm rule?
I have seen some flues which exit combi boilers through an exterior wall, are then routed upwards vertically for a metre or two and then have a 90 degree terminal. I was wondering if such an arrangement is allowable through a flat roof as long as it meets all the other gas safety rules?
