Vertical Type 22 radiators 1200-1500mm height
19 Feb 2015
Are there any Type-22 convection radiators on the market which are 1200mm in height and 800mm in length?
Stelerad's 1200 mm high K2 rads max out at 700mm length. So, wondering if anyone else does these?
Also, would anyone know of any Type-22 radiators on the market which are 1300mm, 1400mm or 1500mm in height (irrespective of length)?
(The next highest Stelrad do after 1200mm is 1600mm as far as I know).
Thanks!
Never seen standard ones in those sizes to be honest.
Stelrad are the only ones I found that do K2 (Type22) vertical rads like that. The others are all column or designer tubular type rads.
From my experiences of Stelrad I would advise you not to waste your time and money.
Like you I wanted a single high quality standout radiator. Ideally British made.
The 1st radiator was delivered damaged, the 2nd had been chipped and touched up in the factory, the 3rd was dented and chipped.
All 3 were extremely well packaged with no damage to the packaging. It was clear all 3 had been damaged before being wrapped and dispatched. Photographs were sent to Stelrad supporting my refusal of each radiator and following the return of the 3rd rad. I requested and received a full refund but not one word of apology or regret.
The delivery was by an unmarked van, of the three 'workers' only one spoke English but even then only partially. I tried to trace the company using the delivery note to no avail.
From my experience I've never had any issue with Stelrad - did you buy direct from them or from another supplier?
I get mine direct from a well known factor who are Stelrad Accredited, who deliver them with their own vans/staff. I've only ever had 2 received damaged, one where the end and top panels were bent - I had replacements for them, from Stelrad, delivered to the factors within 2 days - the other the main front panel was dented, it again was replaced within 2 days with apologies from the supplier.
I guess it does seem to come down to who they come from and how they are sent these days. The quality of some of these carriers leaves a lot to be desired.
