Hi. I live in a C. 1900 end terrace which has various small problems but is, for the most part, quite sound. Earlier this year we noticed condensation on the landing between the bedroom and bathroom, presumably down the showering etc. Started using a dehumidifier whenever we use and it seems to have sorted that out. Great.
Noticed a damp patch on the ceiling again.. checked in the loft and the insulation is soaking! Basically like a giant sponge sitting there leaking away I'm not 100% sure what is causing it.. but the timbers around the apex are mouldy and damp so I'm guessing it could be a leak. Will be getting a roofer out asap to check it.
Whilst musing over the issue I started reading some stuff on here which made me think that the insulation in there is not great. I'm thinking if I can get the roof sorted then what else can I do to reduce damp?
First thing will be getting an exactor fitted in the bathroom. I would like to board the loft out to be use the space for easier storage. Would it be foolish to remove the existing insulation and start fresh with something more modern? Is a vapour control barrier necessary and can this be retrofitted or does it need to go between the plasterboard and joists in the ceiling below? If so would I lay the vapour barrier in between and over the joists, insulate on top, batten the joists and then board? Will 2x1 battens provide a sufficient airgap? I'm 99% sure the existing insulation is rammed into the corners of the roof and stopping any airflow so will be clawing that out tomorrow first thing. I will also upload some pictures as I go..
Thanks!
Thanks!
