Very large tank in attic
26 May 2008
Leicestershire
When a local plumber recently fixed an over flowing warm header tank he commented that the cold water tank in the attic was massive for the size of house. I had noticed that a thin whitish film showed on the surface of this tank and don't like the thought of it. Does this tank feed into the cold taps in the upstairs bathroom? And if so, I would guess that makes it quite unsuitable for home brewing use?
Sorry to be so dense but plumbing has never been an area of expertise for me!
Is there a safe maximum size for tanks in attics?
run the COLD taps and see if the tank fills then you will know.
I wouldn't advise using a tank of any size for potable water, unless it's a special sealed tank.
You should be using mains water.
Your storage tank in the loft may feed your toilet cistern and possibly your cold water taps in the bathroom , it will feed your Hot water taps via the HW tank this was the norm a while back, modern systems have mains fed cold to all outlets but as long as you dont drink the bathroom tap water you will be fine , your kitchen cold tap should be off the mains
Thank you - you've answered my question.
The tank feeds the bathroom taps and no, I will not be using that water for my beer making.
Good luck with the beer making I tried it once and the source of the water was the least of my worries to say what I produced was undrinkable is a gross understatement
