I have the following insert/undermount drainer:
http://www.caple.co.uk/sinks-taps/s...vidual-and-multiple-bowls/zerod45-40-w-500mm/
I want this to be on top of the integrated dishwasher (where often a draining board would be with an inset sink).
The problem is that this doesn't drain in to the sink but has a 90mm waste, and I need a way of getting draining to the main waste under the sink without it hitting the dishwasher.
The lowest profile thing I can find is a Wirquin shower waste that is 58mm from bottom of sink which itself is 25mm from worktop surface (giving a total required clearance of 83mm): http://www.screwfix.com/p/wirquin-pro-slim-high-flow-shower-waste-90mm/10400
Problem is that I don't think this will be enough to clear the dishwasher, and I really don't need the flow rate that this waste will provide.
I was hoping there would be a way of fitting a very shallow waste with an overflow (flat) tube connecting like a normal overflow to teh main waste but I can't find anything.
Anyone got any ideas or do I need to fabricate something myself from an overflow and shallow waste myself?
