Hi I have a steady drip from where the impeller housing joins the plastic casing (at the bottom ) I removed housing, checked and cleaned gasket which was fine, so I rotated it round and re fitted housing.
well its still dripping from the same place at bottom, I notice there are openings into the housing but what could be letting the water pass?
Anybody had this fault, by the way I believe it is a grundfoss pump.
P.S. I hadn,t really noticed before as the boiler is in the loft, but the pump
does seem to be running noisy at times.
Thanks in advance, Ian.
