We're looking to have one of these installed and have had a couple of quotes.
One plumber suggests using 22mm from the DHW outlet (stepped up) as this will help with the flow when using more than one outlet.
The other says that as the boiler has a 15mm outlet that 15mm will be fine and that 22mm would make it take longer for hot water to reach the outlets!
We're very fortunate that our main bathroom and ensuite are next to each other and the runs from the boiler would be about 3.5m in length.
Water main will be 32mm MDPE, 28mm stop cock, 22mm upto the PRV and into the boiler.
Which quote would you go with?
