- Joined
- 23 Nov 2024
- Messages
- 1
- Reaction score
- 1
- Country
Hey folks,
I have been trying to replace the controls on my Viessmann Vitodens 050-W boiler (BPJC type, with the white front panel), switching from a Hive to a DIY OpenTherm thermostat (using ESPHome for those curious).
The goal is to implement load compensation, to adjust the CH flow temperature depending on how many (smart) radiators are calling for heat, and how much each room needs to be heated.
However, the boiler just will not connect to any OpenTherm stat, only working in on/off mode!
The ESPHome one would only show me errors, so I borrowed a spare Nest to test if it was my hardware or the boiler itself.
The Nest would not work either in OpenTherm mode, telling me it was not detected.
Out of curiosity, I then tested my DIY stat on my mate's Ideal boiler (who I borrowed the Nest from), and it worked perfectly!
I have checked the Installation and Service manual and double checked that I'd wired the stat to the correct terminals for OT, and even emailed Viessmann who rather unhelpfully just showed me the same page from the manual I'd been using.
Could there be some setting that needs to be changed on the boiler (not in the manual!), or is it just not working properly?
I'm at my wit's end here, so I'd appreciate if anyone could give me a hand!
Cheers!
also, here's the manual for anyone who wants a look
Cheers!
