Viessmann Vitodens 100-W B1KG - exact OpenTherm terminals on X12
24 Nov 2026
Hi everyone,
Installing a Salus iT600 RX30RF OpenTherm receiver on my Viessmann Vitodens 100-W B1KG.
The manual shows OpenTherm on X12 (low voltage section) but doesn't specify which 2 pins exactly. The terminal cover shows: X7, X6, X2, X9, X12, X5 but X12 has multiple pins and I'm not sure that's the right place to wire it in.
There's also a black plastic cover in that area, not sure if the OT terminals are underneath it or visible already. Please see the attached pictures
Can anyone confirm:
  • Exact pin numbers on X12 for OpenTherm?
  • Any "OT" or "+ -" marking on the PCB?
I can’t see any x12 terminals, maybe under the cover as you say. It should be a screwdriver type connector block
You should have posted this in “plumbing & central heating”.
Have you seen figure 14 (page 28) in the installation instructions?
It is second from the right in his first photo; need to follow those black wires to a screw terminal, according to the instructions.
The manual seems to show D for open them has some connector block. It says "Ensure diaphragm grommets are airtight." so assume must be gas safe to access the connections, so as an electrician all I would do is ensure there is a type A RCD feeding the supply.
