Central Heating system split into 4 zones 3CH and 1DHW Honeywell 2 port valves controlled by Honeywell ST6400 controller and room thermostats. Just had Viessmann boiler as replacement and the switched live into the boiler from the wiring centre needs to be 24v incoming. The existing switched live is 230 volts from the 2 port valves through the wiring centre to the boiler. What is the correct wiring configuration ? Does it need a relay and transformer to obtain the correct switching voltage.
