Viessmann Vitodens 200 WB2B
12 Feb 2013
Lincolnshire
Generally there is a problem with the boiler cutting out after only a few minutes of supplying DHW to taps or showers and not restarting once the cold water supply brings to boiler temperature down to 50oC or lower .
Specifically, is there a "right way up" to install a new Plate Heat Exchanger ??
The Plate Heat Exchanger *7345014* is totally symmetrical so does it matter if the thermistor holder is open end facing "up" or "down" ??
Thank you for any assistance
Regards
Peter
