- Joined
- 25 Oct 2019
- Messages
- 16
- Reaction score
- 0
- Country
Hi All,
I have a Vitodens 100-W WB1B boiler feeding an 8 rad system. There are 6 rads on the ground floor (4 steel and 2 cast iron) and 2 rads on the lower ground (vertical ones). The boiler must be a few years old but the rads are new and I sized them as best I could using the BTU calculators across various websites. We just moved into the property so I have no clue about how good/bad the old panel style radiators were.
Since Day 1, no matter what the dial is set to on the Boiler for heat (the dot point between 4-5 or higher), the boiler temp never reads above 70C. The Burner output shows 1 bar and the flame seems to be on all the time. I also got the plumber to install a Nest thermostat and it never gets to my target temp of 20C. The max value I see is 18C. As an example, 1 hr before I came home, the temp was 14C and the boiler was off. I started it and now 7 hours later, it's still only 18C.
The rads range from warm to hot but barring the cast iron rads, none of the others seem too hot to touch for long periods of time. My question is - is there something wrong with the boiler and what can I test/check?
Any help/direction appreciated.
